Can't find "STVR" ecu when trying to program airbag module
ricedbimmer
New member
Hey guys. I am following TomR's guide https://z4-forum.com/forum/viewtopic.php?t=115539&sid=cf43c72c0a2e70872796231574ab45a5 to reprogram two of my airbag modules.
While the first one was a little bit tricky to get done (SBSR85), I finally got it by changing the diagnosis protocol from BMW-Fast to KWP2000* and confirmed that the VIN was updated.
I can't seem to find the SVTR85 ECU anywhere, however.
I know this module is not in the European cars, which may have some thing to do with it, but there must be some way to reflash this module with the proper VIN. I can't seem to figure out how to do it. Has anyone else encountered this problem on the Passenger Door Satellite.
ZB number is 6927765.
Code:
SGBD : STVR85 - Satellit Tür vorne rechts
Version : 1.03 Satellit Tuer vorne rechts
BMW Teilenummer : 6927765
Hardwarenummer : 06
Softwarenummer : _?_
Lieferant : Siemens
Lieferanten-Nr : 4
Codier-Index : 7 -> 0x07
Varianten-Index : 18519 -> 0x4857
Diagnose-Index : 2592 -> 0x0A20
Herstellerdatum KW/Jahr : -/2003
Fahrgestell Nr. : LT24781
Codierdatenänderungsindex: ??
looks like front door sensor
https://www.realoem.com/bmw/enUS/partsearch?id=BT52-EUR-09-2003-E85-BMW-Z4_30i&mg=65&q=65776961411
Code:
Hardwarenummer : 06
Lieferant : Siemens
Lieferanten-Nr : 4
Did you ever figure this out?
