Yeah the OP has probably moved house by now lolHoly thread resurrection, Batman
Yikes that is a tight space. My slightly portly belly would need a workout before attempting that entry (or exit) lolMines very narrow at 2250mm. Door opening of 2100mm. Bit of a squeeze getting in and out! Foam pad stuck to wall for door protection.
Modern building regs make no mention of sizes for garages. Builders can make garages whatever size they like, as the consensus is that modern cars don't need to be garaged, so garaging is intended for storage.I feel your pain. The only time I had a double garage it was set at 90 degrees to the drive and had two diddy doors, so unsurprisingly never had a car inside but it was handy for my motorbikes!
It really is time the size of a standard garage got increased to reflect the monster size of modern cars, and fitting single doors on double garages should be made illegal.![]()
Or typically gets converted to a long thin room.Modern building regs make no mention of sizes for garages. Builders can make garages whatever size they like, as the consensus is that modern cars don't need to be garaged, so garaging is intended for storage.
