Swapping doors, Any advice?
jamiecarpenter
Post by jamiecarpenter » Thu Jul 03, 2025 9:35 pm
Im finally getting around to swapping my rusty door out and putting on the one enuff-zed sold me last year. Has anyone done this? Any advice? The do's and don'ts? Strip the door first or remove the door first? Ive had a look on the forum but havent really found anything on it other than removing wing mirrors or door cards which I have done before.
Thanks in advance Jamie
Silver Grey 3.0 si 06. Retrofitted sat nav, Cruise Control, Intravee, Door Cards and Heated Seats.
Online
bigwinn
Post by bigwinn » Thu Jul 03, 2025 9:53 pm
I think I did a write up on it a few years back
Not the worst job to be fair- alignment and tightening up you could benefit from two pairs of hands
Obvs take care when dealing with the airbag
And passenger side is easier as you have no barrel lock to swap whereas drivers you do
EWS Delete PM me
Coding- airbags etc PM me
GM5 repair- PM me
Roof problems? E85 and E89 PM me… E86 less so
Online
bigwinn
Post by bigwinn » Thu Jul 03, 2025 9:54 pm
EWS Delete PM me
GM5 repair- PM me
enuff_zed
Post by enuff_zed » Fri Jul 04, 2025 9:09 am
Only done one so far. Found it easy to remove the door complete then transfer everything to the new door before hanging it on.
HQ of 'Norfolk Zed Rescue'.
jamiecarpenter
Post by jamiecarpenter » Fri Jul 04, 2025 7:19 pm
Thanks for link and tips. Im suprised you put everything back on the door before hanging as thought it may be a struggle with its weight and then alignment? There is two of us doing this so hopefully it goes well.
jamiecarpenter
Post by jamiecarpenter » Sat Jul 05, 2025 7:20 pm
Spent most of the day doing this today. The door is on. I need to install the membrane but unfortunately the shut lines and window are not aligning. How did you manage to alter these. Also how did you remove the old butyl tape?
Online
bigwinn
Post by bigwinn » Sat Jul 05, 2025 7:44 pm
I recall shutting the door on the latch then aligning the front 4 bolts making sure all the lines were good
The seal is a bstard: sharp knife and isopropyl alcohol
EWS Delete PM me
GM5 repair- PM me
enuff_zed
Post by enuff_zed » Sat Jul 05, 2025 8:49 pm
Window alignment. Take the door handle off, wind the window fully up and you can see the tail of the mounting bolt. Loosen that and you can move the glass about to align it
