I'm curious about the options below to see if they are a direct drop-in or if there are any issues with fitting a 370 on the front.
I was looking at the M Sport Blue, which I believe fits max 348mm x 30mm
While the M performance below supports 370x30
Probably going to go used either way.
I want brake balance, so improvements to the OEM rear would be needed. But I also want it to look good and fill out. 18" APEX SM-10 wheels
Caliper - BMW (34-11-7-852-120)
https://parts.bmwofsouthatlanta.com/oem ... 4117852120
Caliper - BMW (34-11-7-852-119)
https://parts.bmwofsouthatlanta.com/oem ... 4117852119
I understand there's also the below, which supports the 370mm. Wondering what most would recommend
4 piston caliper 34106855475/6
Assuming this would also work?(also on rock auto which I would go with) https://www.ebay.com/itm/126336763906
Front brake kit questions
- Envain
- B21
Covered in detail what fits etc
https://e89.zpost.com/forums/showthread.php?t=1096917
You won’t need to change the rears if you are using 370mm with F30 calipers
Well within acceptable limits
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting..
- Envain
Thanks, Any idea if the black ones work? looks to be unbranded bmw brembo at a much better price than what i can find.
- B21
The cheapest way is to buy pattern 340mm calipers ..not the factory 370/380 calipers..then buy a 380mm caliper bracket adapter from eBay or other sources and use M2/M4 disks..
Subject to pressing out the captive ‘nuts’ in the calipers with the fresh ones supplied with the adapter bracket it’s the cheapest and easiest solution by far..
In Europe Ridex/ ABS amongst others supply pattern parts..
The 340 and 370/380 caliper pad is identical..
Obviously a change in pad compound such as Ferodo DS2500 will add more bite..then the same pad on the rear would help balance it out..
I do see 345 and 370 rear kits with M5 / F series 5 calipers for more grip / bite / endurance .
https://www.dropbox.com/scl/fi/qscymxyp ... guxas&dl=0
- IMG_0745.jpeg (140.05 KiB) Viewed 154 times
- Envain
Is this the rear adapter needed https://www.seemslegitgarage.com/produc ... -brake-kit, this is what a friend suggested to had a build thread on the 1 series fourm.B21 wrote: Fri Jun 20, 2025 3:10 pm The cheapest way is to buy pattern 340mm calipers ..not the factory 370/380 calipers..then buy a 380mm caliper bracket adapter from eBay or other sources and use M2/M4 disks..
And to clairfy (im dense) The blue M sport (mbadge) 340mm calipers is what youre referring to?
Awesome rear writeup. You sell your kit somewhere?
- B21
Yup that looks like a version of the same idea…so any 340mm F type BMW or copy should work..
My kits will go on sale later in July or August..just finalising pricing / package options
More complex sadly than the fronts
- Envain
Thanks, pulled the trigger on the Blue M Sports. Easier to swallow buying bit by bit spaced outB21 wrote: Fri Jun 20, 2025 4:27 pm Yup that looks like a version of the same idea…so any 340mm F type BMW or copy should work..
Awesome, I'll keep my eyes peeled for when you release them.
- Envain
It appears that these brackets specifically state 380 and indicate that they don't support 370.
Where have you guys sourced other adapter plates from?
