Rear brake pad wear sensor connection location
Hi all, just wondered if anyone knows where to connect the other end of the rear brake sensor . Not the pad end, the other end. Is it behind the seat or maybe in the boot (UK car).It just seems to disappear and looks tricky. Hope someone can help
It’s in front of the wheel …goes to a connection box …Jack the can up and remove the wheel to access
- enuff_zed
I was going to say that, but not sure it's the same on E89??Umfaan wrote: Sun Jun 08, 2025 2:43 pm It’s in front of the wheel …goes to a connection box …Jack the can up and remove the wheel to access
- bigwinn
It’s the same (principle)
EWS Delete PM me
Coding- airbags etc PM me
GM5 repair- PM me
Roof problems? E85 and E89 PM me… E86 less so
EWS Delete PM me
GM5 repair- PM me
Hi, thanks for the replies, but no box near wheel as it is on the front. The end disappears into an inaccessible space to the right and I can't figure out where it goes.
- B21
Yes there is you’re just not looking hard enough…only one location..if it’s covered in road crap trick to see..near the rear trailing arm pivot pointMarauder1964 wrote: Sun Jun 08, 2025 3:53 pm Hi, thanks for the replies, but no box near wheel as it is on the front. The end disappears into an inaccessible space to the right and I can't figure out where it goes.
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting..
Hi just had another quick look and my thoughts are that it's in the wheel arch liner . I followed the cable as far as I could and that seems to be the only logical place. I had the wheel off today but will look again tomorrow
Thanks again
Thanks again
Remove fwd lower wheel arch, see small box.
Thanks , I had a feeling it was there as the cable went off to the right side.
cheers
cheers
