When I start up my car, put in drive, there's a metallic clink or click sound that happens. If I've already been driving, then put it in reverse, the same sound happens. So, some kind of load shift is happening. It only happens once each time, though. So, if I put it drive, it happens, but never happens again while going forward. Same is true for reverse.
I've seen a couple of threads about it, but no definitive answers.
My mechanic says it's likely either the brakes or suspension shifting very slightly and not to worry about it. I'd like to get to the bottom of it, though.
Metallic "clink" Sound - Forward and Reverse
Current
2005 Z4 2.5i
Previous
2018 Chevy Volt
2004 Acura RSX Type S
1989 Acura Intergra RS
1982 Ford Escort
1968 VW Bus
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
Hey Studiowizard,
Did you ever get to the bottom of your "rear end clink" ? I have the same issue on my 3.0si / ~70K miles / 6MT . One Euro specialist said all BMWs do this but I'm not convinced.
There was a TSB from BMW that suggested re-greasing the diff input flange:
And here are a few other forum postings on diff "clunks" ; not sure if the re-greasing will help with a "clink":
Thanks, r3vmatch. That's super helpful!
My mechanic said it's just the brakes repositioning when shifting load from forward and reverse. I'll show him the TSB and see what he says. I'm sure it's NOT the brakes! LOL
Current
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
- Rockhopper
You often find the pads moving slightly in the callipers which makes a noise like that. Some makes of pads are worse that others.
- JordanSecure
I had the same issue when I first purchased my BMW Z4, when switching directions (forward or reverse), or letting off the accelerator a little too quickly, there would be a metallic clunk/clink from the rear end of the vehicle.StudioWizard wrote: Fri Mar 14, 2025 4:41 pm When I start up my car, put in drive, there's a metallic clink or click sound that happens. If I've already been driving, then put it in reverse, the same sound happens. So, some kind of load shift is happening. It only happens once each time, though. So, if I put it drive, it happens, but never happens again while going forward. Same is true for reverse.
In my case, I greased the differential input flange (a metal plate that apparently has some play when changing direction), and I have not heard the sound again.
I made a write-up about how I did my repair, if you would like to take a look
viewtopic.php?t=146371
Best of luck!
- Jordan
That's brilliant! I check it out.JordanSecure wrote: Sun Jun 22, 2025 3:57 pm In my case, I greased the differential input flange (a metal plate that apparently has some play when changing direction), and I have not heard the sound again.
Best of luck!
- Jordan
Current
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
Current
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
2005 Z4 2.5i
Previous
2018 Chevy Volt
1982 Ford Escort
1968 VW Bus
