Mysterious Metal Clanging Noise :-(
cheapshots
Post by cheapshots » Sun Aug 28, 2011 5:22 pm
Hi guys,
Need some advice and help please! I have a 2004 2.5 Z4 with a weird issue.
7 times out of 10 when I change gears I hear a loud, sharp metal clanging noise. It has been like this for a good 6 months now and I'm just so curious as to what it might be. It seems to be happening more frequently now.
Also, sometimes when I depress / release the accelerator the clanging noise can also be herd.
This only happens when I'm driving in or changing into 1st or 2nd, very rarely when I'm in 3rd or above - although it's quite possible I can't hear it when I'm in 3rd as the car is travelling faster and generating more general noise.
Managed to get a few videos for you, you might need to increase the volume to hear the clanging:
Any one out there with a similar issue?
Cheapshots
Shooter
Re: Mysterious Metal Clanging Noise :-(
Post by Shooter » Sun Aug 28, 2011 7:00 pm
10 bucks on the differential silent blocks !
Annoying, but harmless (as far as i know...).
Image Roadster, Monaco blue. Stubby | ZHP Knob | M3 CSL brake discs | M3 CSL brake calipers | M3 CSL exhaust manifolds | Goodridge SS brake lines | Tuned exhaust silencers
jonnyfive
Post by jonnyfive » Sun Aug 28, 2011 8:30 pm
Could be the strut braces need tighten up by the bulk head quite a comon problem i hear .
Live life on the edge or you are taking up to much space!
nmh
Post by nmh » Sun Aug 28, 2011 9:25 pm
Will watch this thread with interest as mine does EXACTLY the same! 3.0, 2003, 41800 miles.
2003 Z4 3.0 Roadster - Gone
2005 645ci Coupe - Gone
2007 Z4M Roadster - Gone
2011 M3 Cabrio
daveparkinson
Post by daveparkinson » Wed Aug 31, 2011 9:17 pm
i think i know your problem the noise come when in reverse if yes its the grease where the prop meets the dif its gone to dust you need to replace the grease not an easy job had mine done in a garage £120
cheapshots
Post by cheapshots » Thu Sep 01, 2011 7:36 am
daveparkinson wrote:i think i know your problem the noise come when in reverse if yes its the grease where the prop meets the dif its gone to dust you need to replace the grease not an easy job had mine done in a garage £120
Hmmm.. Yes the noise can be herd when I put it in reverse, however it can also be herd when I change into 1st/2nd, or as mentioned, when I depress / release the accelerator too..
Blue
Post by Blue » Tue Sep 06, 2011 12:51 am
Happens on mine too!
I'll ask the garage about this lubrication thing tomorrow, see if they can fix it :)
Adamski
Post by Adamski » Mon Sep 26, 2011 8:31 am
Mine does this too.... V annoying :(
Gone: Z4M Coupé|Black Sapphire|OEM CSLs|Aero Skirts|OEM Strut Brace|Nav|Heated Seats|Logic 7 Pro Hi-fi|Bluetooth|Carbon Leather|PDC|BMW Assist|Stubby
Gone: Cherished 2003 3.0i Black Sapphire Roadster
Blue
Post by Blue » Tue Sep 27, 2011 4:16 pm
Anyone got any specific information about exactly which components need lubricating? I've not yet come across a definitive guide and really want to know what I'm asking the garage about!
tombar
Post by tombar » Tue Sep 27, 2011 4:26 pm
I can hear two types of the noise . Loud, low pitch clang and couple high pitched ones. Especially video 4. I'm very interested what are the high pitched ones, as mine does exactly the same when gently acclerating or deaccelerating on low gears.
Z4M Coupe Ruby Black. 220M alloys. sepang bronze nappa. carbon dash. cruise control. nav. pdc. dsp pro hifi. fold-in mirrors. rain sensor. auto-dipping mirror. electric memory heated seats. stubby +other stuff.
Adamski
Post by Adamski » Tue Sep 27, 2011 5:24 pm
Blue wrote:Anyone got any specific information about exactly which components need lubricating? I've not yet come across a definitive guide and really want to know what I'm asking the garage about!
x 2 :?
Also, does anyone know whether we should be getting a shuffle on to get the noise fixed? i.e. is anything being damaged or worn out as a result?
Cheers :thumbsup:
Adamski
Post by Adamski » Fri Sep 30, 2011 5:47 pm
After much searching on the forum, I think our problem might be worn clutch springs.
Can anyone confirm from experience?
Adam
J14RK D
Post by J14RK D » Wed Oct 12, 2011 6:40 pm
Mine does the same. I had it on the ramp and while one mechanic was moving the car forward and backwards with the hand break on the noise can clearly be heard coming from the centre of the diff. I have heard Bout the grease fix but would like more info on exactly what do do and what sort of grease to use.
Stromtech
Post by Stromtech » Wed Oct 12, 2011 11:19 pm
Got the same noise when starting off...thought it might be a U joint needing replaced. Doesn't happen every time.
2004 3.0i 6 speed, Sterling Grey, Premium, Sport and Convenience packages
rich_stockton
Post by rich_stockton » Tue Oct 18, 2011 7:45 pm
yes mine does this every now and then too, if anyone has more info it would be a great help !!!
