E89 Roof Help
E89 Roof Help
Hi guys, I've error codes A692 and A696 , I've assumed they are both codes from the right hand boot ram, A692 being the front Hall Sensor and the A692 being the micro switch!
I've read as much as I can from this fine site.
Can anyone confirm my assessment please TIA
Also has anyone got the part no for the Microswitch?
MY 09 E49 35I
- RobbiZ4
E89 Roof Help
A692 VSW5.3 Microswitch, rear-end module closed, rightRislar wrote: βSun Mar 31, 2024 11:33 am Hi guys, I've error codes A692 and A696 , I've assumed they are both codes from the right hand boot ram, A692 being the front Hall Sensor and the A692 being the micro switch!
A696 VSW7.3 Hall sensor, open circuit, closing movement, rear-end module
Confirmed!
Have a look => Prepare E88 hall sensors for E89 use
viewtopic.php?t=145813
But, don't touch the microswitch!
It's ok, but the first wire in the upper bow of the hydraulic harness is broken. The other 3+2 wires on both sides may be weakend as well and should be replaced with new flexible ones.
Now folks, since this story is repeatedly covered in this forum every week, why is a new thread opened for each case since the solution and recommendations are always the same?
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
E89 Roof Help
Thank you very much Robbi, I did look for specifics before posting just need to work out what you said about the harness
MY 09 E49 35I
- enuff_zed
E89 Roof Help
Worth asking the mods to put your comprehensive thread at the top of the list permanently?
- B21
E89 Roof Help
Good idea..a few standard ones should be parked there..eg cracked alloys..
We choose to go to on with this endeavour at this time and do the other things, not because they are easy, but because they are hardβ¦
E89 Roof Help
Something else I've noticed is when the boot is up and the window shell is on the roof, the motor runs when I keep my fingers pressed on the button, almost like some sort of restriction!! Not sure if it's relevant though!
MY 09 E49 35I
- RobbiZ4
E89 Roof Help
In the upper, not visible bow of the hydraulic harness on both sides of the rear roof shell is tear&wear in the 2 wires on the left as well as the 2+2 wires on the right. Sometimes it's broken, sometimes there are shorts between two wires with broken insulations. In most cases the hydraulic hoses are cutted as well and should be taped to get stabilized. Nothing, that can be done perfectly from below the roof shell.
Try to read all the other trreads with pictures, tips and recommendations for external service partners in UK. Takes time, but is a good investment before destroying more than before.
Wires should be replaced with new flexible ones. I take 0,25mmΒ² LiFY quality) from Conrad Electronics in Germany.
- RobbiZ4
E89 Roof Help
I've tried maintaining a single thread covering all "E89 roof cases" on the ZRoadster.com forum. But it's a lot of work and depends on the discipline of all new users in roof panic.
------- Roof faults folding roof -------
https://www-zroadster-com.translate.goo ... r_pto=wapp
- RobbiZ4
E89 Roof Help
That is a typically consequence of some faults, as the system is waiting on and "hydraulicall pushing" for the correct signal change.
- enuff_zed
E89 Roof Help
Well even a seprate sub-forum would make it easier.RobbiZ4 wrote: βSun Mar 31, 2024 1:36 pmI've tried maintaining a single thread covering all "E89 roof cases" on the ZRoadster.com forum. But it's a lot of work and depends on the discipline of all new users in roof panic.
E89 Roof Help
Thanks again Robbi, I have spent days reading before I posted, right from buying the software to get the codes, read all yours which are great, just wanted confirmation, not upset the apple cart!!
There is a lot of conflicting information out there which doesn't help!!
I appreciate your time!
MY 09 E49 35I
- RobbiZ4
E89 Roof Help
I don't think so, as the same will happen like here in this "E89 problems" sub-forum. Each case will be a new thread and you/we/me have to write repeatedly the same stories.enuff_zed wrote: βSun Mar 31, 2024 1:39 pmWell even a seprate sub-forum would make it easier.RobbiZ4 wrote: βSun Mar 31, 2024 1:36 pmI've tried maintaining a single thread covering all "E89 roof cases" on the ZRoadster.com forum. But it's a lot of work and depends on the discipline of all new users in roof panic.
- RobbiZ4
E89 Roof Help
Top!
Completely agree with you. It's not an easy topic and it's not easy to separate chatter from valuable information.
E89 Roof Help
MY 09 E49 35I
- B21
E89 Roof Help
How about setting up some standard format for some key subjects ..then always point people to them first post irrespective of number of posters..
Intro..explanation of subject area
History of relevant changes
Issues by symptoms and their causes
Issues by fault codes and their causes
Work pack for each sub issue
Notes to be updated over time..
Iβd be happy to do one on ignition or one on wheels or handlimg etc..
