viewtopic.php?t=129048
Regarding "open/close the roof with a running engine":
From my point of view, for the 20-second roof process (20s x 20A = 400As) no more power is drawn from the battery than with 1x starter to start the engine (2s x 400A = 800As).
If that already damages the battery, what happens when the automatic start/stop system is active?
I think the often read engine-must-run recommendation is nonsensical!
But no harm.
My FAQ and recommendation list in the German ZRoadster.com forum:
https://www-zroadster-com.translate.goo ... r_pto=wapp
Important:
There is some maintenance on the E89 retractable hardtop (roof) required.
1) Check the water level BELOW and the corrosion status of the bottom of the hydraulic pump once a year!
Or, if there is no garage for the car, after every heavy rain. There might be water in or below the pump's foam!
Place a plastic bag around the pump's foam to protect it from water. Not around the pump, but the foam! That should look like on the following picture:
2) Replace the 2 salmon relays (12631742690) next to the hydraulic pump with new ones twice a decade
https://www.realoem.com/bmw/en/part?id= ... 2631742690
HowTo: https://www-zroadster-com.translate.goo ... tr_hl=de[b]
Background & installation instruction: [/b]https://translate.google.com/translate? ... ue.133521/
Don't care: about the "Axx" numbers on the new relays. This is a production/manufacturer and not an amperage info. It may differ from the old relays.
Technical background regarding melted hydraulic pumps:
https://www.spoolstreet.com/threads/urg ... lays.3815/
3) Replace the 2 microswitch coupling lock (54377228585, 54377228586) with new ones every decade
https://www.realoem.com/bmw/en/part?id= ... 4377228585
https://www.realoem.com/bmw/en/part?id= ... 4377228586
HowTo: viewtopic.php?p=1828044#p1828044
and
viewtopic.php?f=45&t=129556
Important: Always replace both microswitches, on the right as well as on the left!
4) Think about a replacement of the hydraulic harness (54377311084) with a new one every decade
https://www.realoem.com/bmw/en/part?id= ... 4377311084
HowTo: viewtopic.php?f=46&t=122363
5) Check and/or replace the coolant reservoir cap with a new one every decade
Have a look at the following thread:
viewtopic.php?p=1947122#p1947122
With these simple (sik) steps you can avoid almost any disturbance with the retractable hardtop of our E89.
6) Check your backlightclusters
Please have a look at the number of nuts on each backlight in the trunk. Replaced backlights have only 2 nuts instead of 3 of the initial ones. In that case, the 3rd hole in the body has to be sealed from the outside BEFORE mounting/replacing the backlight cluster! If not done, your trunk will transform to a swimming pool!
A round seal (07147162569 protection foil) for the 3rd drill hole is available from BMW.
And please mount the backlights in a correct manner: the gaskets have to be pulled very carefully on the rubber flaps into the body before/while you fasten the nuts.
7) Anoher don't, but important from my point of view:
Don't use any lubrication in the roof, it is not required.
To get a better understanding why not to lubricate, have a look at the bearing bushes:
viewtopic.php?p=1829498#p1829498
Before there are further regular inquiries:
There is no practical way of checking the condition of the electrical and hydraulic lines on the E89 without dismantling the roof. It cannot be visually checked from the outside.
A useful tool for worklng in the trunk:
To get the black pins of the internal trims removed the following tool (nail iron) is recommended instead of fighting with a screwdriver or a small pair of pliers!
Fault codes assigned to the 2 hall sensors on the right hydraulic ram in the trunk:
Emergency procedure to open the trunk lid:
viewtopic.php?p=1852241#p1852241
And please, once again and again and again, don't use WD40 anywhere in the roof's construction!
To check CC codes use one of the following pages:
https://www.autobulbsdirect.co.uk/blog/ ... ror-codes/
https://www.drive2.ru/l/4628359/
https://bimmerguide.de/check-control-me ... odelle-v1/
Update 03/2022:
There might happen a tricky fault on the boot lid: if the brake light gets activated, the trunk lid opens while driving.
Have a look at the following description:
[Deleted]viewtopic.php?p=1909115#p1909115
viewtopic.php?p=1725032#p1725032
This blue plug of the trunk lid harness can be found on the right next to the backlight cluster.
Update 05/2022:
The product I use to maintain the rubber seals of the roof. It's silicon free.
