E89 hall sensors (HS) on the hydraulic rams are very expensive as spare parts. Alternatively, E88 hall sensors can be fitted. These HS use the same housing format, but are supplied without connectors.
What is required:
Preparing these E88 hallsensors is easy going: 8) :?
Roof fault A691/A696 Hall sensor
z4-forum.com
What is required:
- 2x Hall sensors E88 54347190735: https://www.realoem.com/bmw/en/showparts?id=UM91-EUR-03_2008_E88_BMW_118d&diagId=54_0392#54347190735
- 2 male MQS pins per HS
- A MQS crimp tool
- Remove the zip tie from the hydraulic ram, that fixes the rear hall sensors plug.
Take a photo before removing it! - Both hall sensors are clipped into the right hydraulic ram in the trunk. You can unmount it by pushing a tiny screwdriver between the ram and the HS housing
- Shorten the 2 wires of each new hall sensor according to the lenghts of the old hall sensors, they are different
- Crimp a new male MQS pin on each wire.
- Twist both wires to get the wiring a bit more compact.
- Plug both wires into a new housing.
- Important: pin orientation is according to he old hall sensors - brown to brown, colour to colour!!. One old HS has a yellow wire, the new one is red. Don't mind, just colour to colour.
- Don't forget to place a new zip tie sorrowly(!) around the hydraulic ram to fix the plug and the 2x2 wires as initially removed.
Roof fault A696 Hall sensor
The fault appeared on my z4 when opening and closing the roof. On opening the cycle stopped when the roof package went in the boot and the boot lid failed to close. On closing the roof failed the connect with the windscreen. In both circumstances the cycle could be completed by holding down the...
