What is it really useful to know as a new e89 owner?
JakeS76
Post by JakeS76 » Wed Feb 28, 2024 4:59 pm
It's got loads of options but not the extended lighting unfortunately. It has the ski hatch option and lots of netting around the cabin so I'll have a look for a driver's side cubby hole by the steering wheel.
Pondrew
Post by Pondrew » Wed Feb 28, 2024 5:32 pm
JakeS76 wrote: Wed Feb 28, 2024 4:59 pm It's got loads of options but not the extended lighting unfortunately. It has the ski hatch option and lots of netting around the cabin so I'll have a look for a driver's side cubby hole by the steering wheel.
If you have 'netting' and the elasticated straps in the boot, then you have 'extended storage' so you should have the coin holder drawer aswell.
2024 Audi A4 avant 40 black edition petrol
2025 Ford Focus ST 'track pack'. Go-kart with sat nav.
Z3 'free litre'. Project and a half.
No Z4 anymore!
JakeS76
Post by JakeS76 » Sat Mar 02, 2024 4:14 pm
It has a cubby hole by the steering wheel. Thanks for the pointers
JakeS76
Post by JakeS76 » Sat Mar 02, 2024 4:17 pm
Either side inside the boot / trunk is a warning sticker for No bags. I'm assuming this is because if you put a bag there it will block the roof opening mechanism? Or is it ok to put light bags there?
javis20
Post by javis20 » Sat Mar 02, 2024 4:32 pm
Don't even put a kernel of popcorn there. Roof will jam. Also never leave that little compartment door open. Again the roof will seriously jam.
Pondrew
Post by Pondrew » Sat Mar 02, 2024 4:35 pm
JakeS76 wrote: Sat Mar 02, 2024 4:17 pm Either side inside the boot / trunk is a warning sticker for No bags. I'm assuming this is because if you put a bag there it will block the roof opening mechanism? Or is it ok to put light bags there?
You can put whatever you like there, as long as you don't open the roof!
Because both roof panels are curved, when stowed they 'droop' at both sides into that area.
Best bet is to open the roof, then open the boot to see how much room there is. That will tell you what you can and can't fit in there.
I tell my misses not to put ANYTHING there, ever, just in case. A damaged roof panel or hydraulics is not worth the risk IMO.
No Z4 anymore!
JakeS76
Post by JakeS76 » Sat Mar 02, 2024 4:42 pm
Thanks both. It's a bit mad that BMW didn't put side partitions there to stop anything from ending up in that bit of boot space.
Pondrew
Post by Pondrew » Sat Mar 02, 2024 4:47 pm
JakeS76 wrote: Sat Mar 02, 2024 4:42 pm Thanks both. It's a bit mad that BMW didn't put side partitions there to stop anything from ending up in that bit of boot space.
Once the 'shelf' is in position nothing can fall across into either area easily. They are also higher than the main boot space. Just think of the boot as somewhere to store the roof, nothing more. :D
No Z4 anymore!
JakeS76
Post by JakeS76 » Sat Mar 02, 2024 4:50 pm
Can you adjust the bonnet /hood catches? The bonnet shuts fine and stays shut while driving. But one side feels slightly high so I can press down on it a few mm.
B21
Post by B21 » Sat Mar 02, 2024 6:38 pm
Quite a complex operation involving the hinges and catches..need access to TIS really to do the job or off line workshop manual..
One of 258 Atacama Yellow 35is…165 modifications and updates…and counting.. :tumbleweed:
Silverstar
Post by Silverstar » Sat Mar 02, 2024 6:55 pm
JakeS76 wrote: Sat Mar 02, 2024 4:50 pm Can you adjust the bonnet /hood catches? The bonnet shuts fine and stays shut while driving. But one side feels slightly high so I can press down on it a few mm.
There are four rubber bungs which you can adjust the height of by turning them clockwise or anticlockwise. It might help. You can see one in your photo I've highlighted it in the red circle, there is one on either side and then another one either side a bit higher up. I think you can just about see it on the bottom edge of your photo.
RobbiZ4
Post by RobbiZ4 » Sat Mar 02, 2024 9:35 pm
JakeS76 wrote: Sat Mar 02, 2024 4:42 pm It's a bit mad that BMW didn't put side partitions there to stop anything from ending up in that bit of boot space.
Why?
It's the intended area to place the roof into. Any additonal partition would block the roof - or better would be crahed by the roof. 8)
:ant:
Z4 E89 Roof Topics
viewtopic.php?t=130932
Y1 ... Y4 Roof Diagnostic Systems for BMW, AUDI, VOLVO
viewtopic.php?f=23&t=129048
JakeS76
Post by JakeS76 » Sat Mar 09, 2024 10:32 am
I've got the interior colour code LCYC. Could anyone tell me what colour this is as I wanted to get some leather dye to cover a small mark on one seat. I'm guessing it's some kind of beige or cream.
JakeS76
Post by JakeS76 » Sat Mar 09, 2024 10:33 am
Sorry it's LYCY
N4LLY
Post by N4LLY » Sat Mar 09, 2024 12:10 pm
Pondrew wrote: Wed Feb 28, 2024 5:32 pm
[/quote]
I have "Extended storage package". Where is this coin holder drawer you talk about ? Only had car 5 plus years, discovered no hiden drawer ? :?
2014 20 M sport Valencia Orange
