Just Fitted My Intravee
n1k_85
Wolverhampton, UK
Hi All,
I Have just fitted my intravee to the Z4 (While parked up in my work car-park :lol: ) The whole install & Laptop Setup took around 20 minutes.
I decided that since i will probably be removing the Intravee when i sell the car i decided to leave the CD Changer in situe. I also may install a TV Module in the future so I can always remove it then if need be :)
I just used a Stanley knife to cut an 'X' around the pull string on the rear wall boot carpet and flicked it out like a big button. With this done the carpet can be easily lifted with a full view of the rear of the CD Changer. I Whipped out the wires to that and plugged them into the Intravee, then the intravee into the Alpine Unit. I fed the iPod lead through the gap between the Nav DVD Unit and the CD Changer. From inside the cabin i could see the end connection of the iPod lead but couldn't quite reach it to pull it through, so I (very carefully) inserted a large flathead screwdriver (covered in a rag) into the gap and turned it slightly to open the gap a little more. It only needed about 1mm of space and using another small screwdriver I was able to extract the end of the cable.
After i had used a Laptop to change the UI settings on the Intravee (I bought it used with a different setup that mine) I temporarily secured both units using velcro to the rear wall and replaced the carpet.
I have just ordered some of this on eBay to secure it fully:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=250365687850
I used the same stuff on various parts of my VX220 and was very impressed with the strength of it. Its like velcro but there is only one side (no male/female) and it is so strong that you have to really give it a good pull to get it apart. :thumbsup:
I have only had a quick play with the iPod in the car while parked up, but i will add to this thread later on when i've used it a little more.
From what i've seen so far it seems great! I had an Alpine iPod H/U in my old car and i missed it like hell when i moved to the Z4! I hate having to burn stuff to CD every time i want to change the music in my car :thumbsdown:
The only problem is that I left my 16GB iPod with the buyer of my old car :roll: so now i'm left with a 2GB until he sends it back in the post :)
Here are a couple of extra pics i took today showing how I accessed the rear of the CD changer, the BMW owners manual folder came in handy to allow easy access :D I have since cable tied and tidied up the wiring.
Excellent :thumbsup: I'm about to order the intravee2 for my car and was gonna get someone tofit it but having read your 'how to' I'll save the money and do it the same way.. :D
Can you display the navigation map AND also the select a track on your ipod? In other words, does the does the navigation map go away when you select a track on your ipod? I have NAV and DSP, and it's really a deal breaker for me since I like to always have the map visible...even if I'm shuffling through tracks on my ipod. For this reason, I opted to install an AUX input, even though the sounds quality isn't *perfect*.
The NAV has a split screen mode that allows map and music at the same time.
