Person not needed in seat for comfort access closeflybobbie wrote: ↑Mon Mar 11, 2024 12:10 pm Thanks.
I took the switch apart and attached wires to circuit board and reinstalled.
Project was to use a remote control to open and close roof.
Then realised i needed to power module when car unlocked, easy i think, but needed ignition key in..
As we know we can open roof but not close with basic key fob.
Also does car need to detect someone in seat to operate close function.
That little project was abandoned.
Roof opens with Key fob but not with inside switch
- B21
- RobbiZ4
OK thanks, one less thing to have thought about.
Well if your goal is to simulate a SmartTop or Komfort Access, you should be looking around the CTM module. Smarttop in installed inline with the CTM module connector and only uses 5 wires. You could possibly program and use an Arduino to open and close the top. You can buy remote control modules for the Arduino. If you knew someone with a SmartTop you could ask them to identify which connector pins it's using.
I was going to tackle this project a few years ago, but then realized I'm retired and life is too short.
Same here, after messing with the push buttons and adding wires, it became...what's the point.
Passed a few hours away.
I have a simple 4ch remote switching relays.
There must be some signal that perhaps is replicated in smart top to tell the system in effect ignition is on to close roof.
Have seen the various wire in the wiring diagrams. Might come back to it in summer.
- RobbiZ4
Well, I've integrated such a 4CH China relay package into my Y3 Diagnostic System:
viewtopic.php?t=134505
2 channels are for opening or closing the roof by putting the according input ports to ground (simulating the internal buttons).
2 channels are for opening or closing the front locking system independant of the roof for maintenance and diagnostics.
The prerequisite for using these 4 functions with my system is that the key is inserted into the FOB slot in the car. But the ignition is NOT required to control the functions mentioned.
So far I don't know how the roof modules activate the car's environment, but I'm pretty sure they send a message on the redirected CAN bus.
Pardon, je suis Allemand
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Yes i have the same module and key fob.
All i need do is connect it, but the fact the cars key fob needs to be in ignition is only convenient if trouble shooting and need to be outside car moving the roof.
If a signal could be replicated to say the key is in, it would be worth it.
Would be even better if the boot open key on car fob could be changed to roof close.
It always seemed a pointless function unless boot opened fully, like my colleagues Merc.
I have a SMARTOP installed and mine still does the same thing but now the action has changed, now both roof buttons on the inside work and only the close on the fob functions! I still think it's the module.........yesterday whilst the roof was CLOSING it stopped midway and the trunk popped OPEN: cry: !!! I can bet that the roof module controls the trunk lock/unlock action.
Had a quick look smart top. Can you reprogramme it through usb port?
Yes, comes with a cable and instructions on their site.
- Chippie
You can also program it from the roof buttons inside the car
I think it is worth mentioning that something is up with my fob, batteries last about a week to week and a half! so now I'm not sure if it is actually the module or the key! I am in the process of replacing the fob, so I'll see what happens and report back.dumaurier7 wrote: ↑Tue Mar 12, 2024 11:50 am I have a SMARTOP installed and mine still does the same thing but now the action has changed, now both roof buttons on the inside work and only the close on the fob functions! I still think it's the module.........yesterday whilst the roof was CLOSING it stopped midway and the trunk popped OPEN: cry: !!! I can bet that the roof module controls the trunk lock/unlock action.
