Zed's maiden voyage
Wood Butcher said:
Felt like a bit of a tool when I first tried to fill her up, the pump kept shutting off constantly unless I trickled the fuel in gently, so blocked the forecourt for a while. Not a problem though, I was only holding up a caravan!
Nice Zed!
I found this at first, try holding the nozzle at a slight angle from one side. You'll soon get the knack of it.
Thanks guys!
StuartH, I will check out those roads you mentioned around Holmfirth. Although it's not that far from here, it's not an area I've explored yet. Anywhere with a nice smooth road sounds good to me!
Thanks also to those posting their tips to get out of the car without slipping a disc :lol: I'm sure I'll manage with practice, getting in is easy enough.
And finally the fuel issue. Have tried angling the nozzle as suggested by Scott202, which did help, but still shut off quite frequently. Usually I use my local Sainsburys, but tried a Shell station when I was out, and had less of a problem there filling her up.
Looks like the pump nozzles make a difference.
Wood Butcher said:
I need some urgent help.
How do I get rid of those dark grey fluffy things in the sky, that are leaking to go away?? :(
They happen if you drive too slowly. Speed up a bit and they go away.
