B bigosean Member Manchester Nov 30, 2018 #1 As above I’m looking for a Z4M front bumper, lower plastic grills and ideally under tray. Not too fussed if it needs paint but not cracked/ damaged, if it’s a clean one in Silver Grey happy days. Cheers Sean
J JINGLE Veteran Norwich, Norfolk Dec 1, 2018 #2 Don’t forget the brake air ducts, brake air ducts brackets, and potentially the lower corners (although you can simply modify your existing) Good luck in your search
