Z4M Eventuri Ram Air Scoop
Kernow-Z4
Laser Cut from Aluminium the Z4M air scoop directs ambient air directly into the intake and effectively keeps IAT's down.
Easy to install, no drilling required. This scoop simply clicks into place using the factory hole locations and supplied fixings.
The scoop has been fitted previously in conjunction with an Eventuri intake, it looks to have been previously painted black instead of the standard garish red, it is in good condition and will function as intended.
£40 including postage.
Any questions please ask.
If this will fit on an 3.0si, assuming it's just the scoop that sits behind the grilles, I'll take it please!
Good Afternoon,
Unless mistaken, I believe these are only compatible with the Z4m.
The scoop is fitted to the extreme right hand corner through the kidney grills, it replaces a small "quarter bowl" that's usually there.
This above is applicable if you were to be looking towards front of the vehicle.
Unfortunately I don't have a Z4 anymore to check, please check and confirm if you are still interested?
It can be on any Z though as with a simiar RPI scoop they were the same for M or non M
Kernow-Z4 said:
Good Afternoon,
Sounds like it will fit so I'll drop you a message to sort out payment etc :thumbsup:
