Sim_Simma said:
Beedub said:
sim.
cheap way to gain meaningful camber without the need for top mounts which can lead to added NVH. ( i run these as well as camber plates)
http://www.turnermotorsport.com/p-424-front-camber-bolt-kit-e36-z3-z4-m-turner-motorsport.aspx
, combined with the stock scope for adjustment a decent -1.8ish is achievable, this combined with a tweaked alignment and some decent tyres will REALLY combat a decent amount of understeer that is naturally dialled in by bmw to keep the average joe safe, turn in will be improved also.
see.... cheap fix, and so easy to install yourself.
now get ordering, you can pick them up from CA automotive for around 20 quid.
Excellent thank you mate. One question, how will the tyres fair in day to day driving with that much camber?
Not to bad if your a spirited driver...
let me give you an example..
i run -2.7! the wheel is visually slanted to combat outer shoulder wear i experience on the sprint circuits, the wear is enough even with all that camber that combined with the normal driving i do also i get a dead even tyre wear... obviously i understand your car won't see what my car see's BUT, don't dial in that much camber, the shims have 3 levels of adjustment by using a certain amount of the shim washers provided.
