Ed Doe said:Tom I didn't know that - so does that statement regarding the deployment of leading pistons on 4pot upwards calipers apply to all calipers or just specifically to the Porsche ones?
I've just got hold of a set of the bmw performance 6pots and csl discs to fit to my non-M Coupe, I was intending to leave the rears as they are certainly for the time being - curious as to your experience regarding biasing issues? I wouldn't have thought the bias would be significantly affected.
I certainly found the oe stuff doesn't hold up to track well last time out at Goodwood - the pads are totally shagged now, hence the look for a sensible upgrade!
Missed all the fun this morning
Ed, yes essentially the rear boxster calipers used in this application on our cars are mounted on the rear of the hub whereas in a boxster they are mounted on the front. These (and I believe most multi piston) calipers have different sized pistons front to back so that they apply different pressures over the pad, as the leading edge of the pads will tend to bite harder due to the inherent dynamic forces between pad & disc. The slightly smaller piston applies less pressure to the leading edge thus balancing the pressure over the pad.
Having it the wrong way round with the larger piston on the leading edge is probably not going to make a huge difference to braking capability but it will surely lead to uneven wear on pad. Fortunately the solution is very simple, just swap the link tube so that the bleed nipples sit at the top of the caliper. I'm sending my CV off to Red Bull asap :lol:
As for bias, there is a fairly simple calculation you can make to see what you're messing with, but no I doubt it's going to be a huge issue for you particularly as the bias in your case will be going towards the front. You could perhaps use a more aggressive pad compound in the rear to compensate if you feel the need.
