Z4M Bilstein Suspension
mpm
Hi all. For sale I have my bilstein suspension set up.
I bought the car with these on them, and having done some research I believe they are the following set up.
Bilstein shocks with Ground control adjustable spring kit, inc Ground Control Adjustable top mounts, and rear height adjustment with rogue engineering strut tops.
This is a rare set up, which for UK roads was superb.
The only reason I’m selling them, as I now have a coupe with KW coilovers, so I’m selling the parts from my Roadster. They have covered approx. 7k miles.
I’m looking for £550, ideally collected from Bracknell RG12, due to the size and weight, however will meet within a 50 mile distance from here if it helps aid the sale.
Here are some photos.
JonLeeper said:
Perfect timing as I was about to buy new suspension. IAs long as they'llfir an e85 'll taken them.
If they're not suitable for a 3.0 E85, I'd like 2nd dibs, please :thumbsup:
That's a 3.0Si I'll have you know! Not the common garden 3.0i! :rofl:
They came off my M Roadster. So can confirm they fit M cars, but wouldn’t like to say on non M
Well it looks like they won't fit my Zed. Therefore I, regretfully, pull.out leaving this bargain to you.
to confuse matters, my "common garden" e85 3.0se has factory fitted m sports suspension - so it theory that would fit mine or anybody with m sports suspension ?
btw - i dont want them - i want soft soggy comfy suspension :o even though they do look damn sexy ...................
No apparently they wouldn't fit yours either. My 3.0Si Sport has the whole works too. The Z4M had completely different wishbones and mounting points for the suspension. Or so I've been told. So this will only fit Z4M and not a standard Z4 regardless of spec.
Would those adjustable rear spring perches work on my B8's with H&R springs i wonder?.... and i'm guessing the camber plates would be a direct swap onto my B8's?
seems to me there are more variables on a z4 than farts in a tin of beans :o
BUMP still available.
The thread seems to have got a bit cluttered. Any chance a mod can clear it up?
mpm
..Apologies...
I’ve pondered; completed further enquiries today & l’m now going for a new set of KWv3 coilovers..
Sadly, they don’t come with the Rogue Engineering top mounts - like your set does🙄
Hence, I’m out..
Best of luck with the sale however 👍
Anyone interested? Open to sensible offers.
I’ve just stubbed my shin on them, so would be good to get them out the way :driving:
Did you buy these new from Bilstein (or other supplier)...if so, do you have the original proof of purchase so they’ll honour the lifetime warranty?
