Z4 Sometimes hesitant to start
MarcBMWZ4
This has been a recent occurrence where when turning the ignition, the engine turns but it sounds like its not catching and I have to do it a couple times before it gets going.
It sounds like one of those very old cars that struggle to start in the morning. :oops:
Anyone have any ideas as to what could be the issue?
Many thanks
Starter motor on the way out? Could be quite a few things based on the description, maybe try taking a video?
Fully charge your battery and then immediately try starting the engine (from cold). If it starts properly, your battery and/or alternator may be due some attention/replacement.
Check if your orange equipment test/fault lights come on the dash as soon as you turn the ignition switch. If they don't it could be a dodgy ignition switch contact causing an intermittent fault, as that is quite common and an cheap/easy thing to fix.
