Z4 roof needs a gentle nudge to open, foggy headlights
omiZ4
New member
Hi I have a 2004 z4, i have a problem when opening the roof. when i press the button the roof opens about 5cm then i need to gently push it up while pressing the button for it to open. feels like it doesn't have enough power to pull it up. when i close the roof it works perfectly. if i need a new motor how much would it cost. Also i have some moisture building up in the head lights when i wash the car and usually dries out if its a sunny day. if you can please help it would be very appreciated
Don't know much about roof motors but moisture problem probably requires new rear covers from stealers
Is this with engine running or not?
I have the same issue if I try to be 'flash' and blip it to open as I approach the car, but have no problem if engine running, so I suspect it to be the battery strength.
Get the roof half open then spray all the hinge joints with silicon gease (available from Halfords etc). Work the roof up & down a few times so the lube penetrates the joints. Keep putting more lube on until the roof moves nice & freely.
My E36 had the steamed up headlight issue. It's harder to access on the Z4 but unclip the bulb covers on the back of the headlights. Drive around for a week or two & the lights will demist. Put the covers back on. Jobs a good 'un.
