Z4 rocker cover gasket problem
It might help if you post the exact model of your car and check the required part number on Realoem parts site using the last seven letters and digits of your Vin number. Once we know that it can be checked on the AutoDoc parts site using the part number. It certainly looks to me you have the wrong gasket it should sit in the recess in the cover a lot more than shown in your photos.
https://www.realoem.com/bmw/en/select
https://www.autodoc.co.uk/
The Elring part number 382.711 you have shows up as a 2.0l E85 so if yours is a 2.0l then it should be right.
That doesn’t look like you’ve pushed it in at all? It will sit about 1-2mm out but compresses when you tighten it down
Thanks for the messages I spoke to company I bought it off and the one I ordered off their website is the wrong one even though it states it’s for my z4 2l they gave me the link to order it off eBay which I have done even tho the description says for an x3 so fingers crossed
I measured the groove approx 4mm the rubber to be inserted was 14mm so no way was it going to fit in
Frustrated z4 owner
Frustrated z4 owner
That’s worth remembering thank you :thumbsup:
