Should be a relatively quick fix if you have reference to look at and put it back. I can't tell how it fell that easily. May be it has been played with from previous owners!Rafa8 said:Just checked on the parcel shelf you mentioned and found the sensor arm on its own.
See attached photos.
A beginner foxwell scanner may come in handy!Rafa8 said:Hi
I have an issue with the DSC display light on the instrument panel, it will not go away, any ideas please why this there, I have read it could be the sensor on the wheel causing the problem?
Either the sensor or, as was the case on my 2007 car, the reluctor ring which sits on the drive shaft and provides the sensor with it's readings. These corrode over time and become distorted, giving rise to false readings and warning lights.Rafa8 said:Hi
