B bobo075 Member Feb 12, 2018 #1 Hello, I was wondering if the Z4 M's excentric Wishbone bracket would fit without problem a standard Z4 ???
S Steve84N Senior member Feb 12, 2018 #2 Yes it does but it's the bush that's eccentric and the bracket is the same. A good mod as the extra castor and hence camber mid corner gives more grip.
B bobo075 Member Feb 12, 2018 #3 thank you Steve for this information, I had done it on my E30 and I wonderers if it was the same
S Steve84N Senior member Feb 12, 2018 #4 I did it on my 3.0si Coupe and it was one of the more noticeable improvements.
S Stevie.w Member Edinburgh Feb 13, 2018 #5 I fitted power flex bushings that are made with the off set in them.
