Z4 M Coupe - All/Rear Springs
simonlpearce
I know it is not that likely, but in case anyone has any spare i could do with a set of rear springs for a Z4 M Coupe, probably the same as the MR???
Drop me a PM if you have anything, otherwise i will have no choice but to lower it 8)
Yes the rear springs are the same for roadster and coupe, it's the dampers that are different.
OE as maybe, if the OP was contemplating getting a replacement set of 4 Eibachs (being cheaper than a pair of rears), those are not.
And I have a singlet if he wants it - no good to me :)
Ah ok I misread. You are though wrong.
E10-20-010-04-22 (E86M)
E10-20-010-04-22 (E85M)
http://www.ebay.co.uk/itm/EIBACH-PRO-KIT-LOWERING-SPORT-SPRINGS-SET-BMW-E85-Z4M-COUPE-CONVERTIBLE-ONLY-/390784812922?hash=item5afc97077a:g:xgQAAOSwzrxUzrog
And your E85 M Sport single spring will be of no use as that's for a different car.
Gosh, another combo to add to the list! Do they have the same fronts? Non-M coupe and roadster have different rears, 4/6 pot different fronts.
I don't think it will be of any use for anyone!
Same springs all round for the M coupe/cab whether that be OE or Eibach, not sure about H&R and others.
It's just the dampers that are different between coupe and cab M's, both front and rear.
I did consider lowering, but am likely to sell the car soon so not sure i want to go away from OEM as a potential owner can then make up their own mind.
