RobManning
Hi all,
I think my electric power steering motor has failed so am looking to remove and send off for test and refurb.
My question is, what's the easiest way to get the motor off myself? I've seen some people taking the who steering column out but I was hoping to avoid that.
My main questions are:
1) Can I leave the steering wheel + airbag on and loosen the column enough to twist it round to get to the motor torx bolts?
2) If I have to remove the steering wheel + airbag, can I loosen the column enough to twist it round to get to the motor torx bolts
or am I going to have to face the worst, remove steering wheel, airbag, and disconnect the column from the bottom end rack & pinion...
Is there a quick method??
Any help greatly appreciated please.
Thank you.
Rob.
Thank you.
Rob.
