z4 E85 Passanger seat
olsonn
Car has just failed MOT on airbag light. Looks like it is the passenger occupancy sensor. Looking for a cheap passenger seat to get through the MOT and then sort out a new occupancy mat. Did try an emulator but didn’t work
Where abouts are you?
In case you didn't know the airbag light has to be turned off with a code reader.
For £40 you could get this by 1pm tomorrow if you're quick, then properly diagnose and reset the airbag yourself...
https://www.amazon.co.uk/Scanner-Airbag-Engine-Diagnostic-Suitable/dp/B00KL4H2G0/ref=sr_1_1_sspa?keywords=c110+scanner+bmw&qid=1682530549&refinements=p_85%3A20930949031&rnid=20930948031&rps=1&sprefix=C110%2Caps%2C181&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1&smid=A3LI5U7VWE9VOQ
I bought one of them first, but my seat doesn’t have the black box under the seat that these fit into. I upgraded my seats to the Z4M seats
You'll then need to cable tie it up under the seat out the way of anything moving
Just used the £40 scanner mentioned in these comments, error message for airbag and it said under voltage, cleared the error but the light is still on
Satellite b pillar left is the fault you need to clear
I think its error code 9895
After a visit to Zed Shed in Newton Le Willows, problem identified in less than 15 minutes, a crack in the clock spring, secondhand replacement fitted and airbag light removed. Once again, can’t praise Mike enough, always the go to guy for my Z4
