Z4 E85. M Steering Wheel
Umfaan
 Miskin , South Wales
As per pics in good condition .
Can include Airbag or use your own .
£198. inc postage in the UK.
Howdy. Any idea if the steering wheel controls are plug and play on an 04 with a DSP set up?
If so, can I have first dibs on this?
Yeah …..plug and play.Cars up to Sept 03 will need a 2 wire modification.
Will Pm you
Will Pm you
Not strictly Zed law. You may need to check you have the wiring in place even after Sept 03 as there’s no guarantee its there. Retrofit cable will then be required to tap into the light switching unit.
A very simple2 wire modification if needed. Easy to check ….see if you have a wires in the bottom plug on the squib ….position 9 &10 ..if so will work…or £11 … 2 wire loom available on EBay .
