Z4 E85/E86 trim for sale
I went and pretty much replaced all of the trim in the car which did not look as new and now I have a few bits left over.
The parts are good to be painted/experimenting and some are brand new and never fitted :)
The car has 55k miles on it so the wear isn't excessive.
Driver's side door handle: £10
The handle itself is brand new (the black trim is not) I did not end up replacing it because my trim had the darker chrome which is no longer in production (you can see it on the door pull trim below)
It comes apart easily (one plastic bolt holds it in place) so you can just replace the chrome part.
Passenger side door pull dark chrome trim: £10
Driver's side trim (part 5 from here http://bmwfans.info/parts-catalog/E...N/apr2006/browse/vehicle_trim/cover_entrance/) £5. few marks on it
Hazard & lock switch £10
Centre console oddments tray. few marks on it. £5
Driver & Passenger door sill strips £5 each.
Centre console (under the handbrake trim). It is cracked but it is held by something like 20 screws underneath and the crack cannot be seen once installed because it is so tight £10
Driver's side door pull trim £5
Driver's side cup holder face plate trim £5
Centre console clips (brand new never used) These are for the large dash trim around the radio and also the small one around the light switch £5
Rearview mirror trim (brand new never fitted) for mirror with light sensor £5
The postage is £5 for anything that will fit inside a large, A4 envelope, and £15 for the larger pieces which will not.
If you're interested in a few parts I can look into postage costs.
