brin1960 said:I currently own a Z3M Coupe and love it for its outright rawness and driving appeal i.e. totally connected to the road. I have just sold my M240i Daily Driver as it was just Soooooooo boring!
My Dilema is do I buy a Z4 3.0 si Coupe or the Z4M Coupe as my daily driver. Bear in mind that I will sometimes have a passenger so a reasonable ride is a minor priority.
Cost is not an issue (I can pick up a really good 3.0 si for under £10K or a Z4MC for circa £20K) it is simply a case of which is the best for a DD considering that I also have an S50 Z3MC.
All comments appreciated
As you have the Z3 M Coupe, have you considered a Cayman?
I know I probably shouldn't say it on here, but as a daily it is spectacular.
A 987.2 from 2009 with either the 2.9 or 3.4 would be my choice.
Out the box the suspension set up is just spot on, just really well damped.
The Z4 imho, really needs money spent sorting the damping out, firmer dampers with a progressive spring that has a slightly lower spring rate when pootling about but firms up when pressing on, Eiback pro kit is a good choice with a B6 damper.
Plus put on PS4s or similar.
Then you have the EPAS steering on the non M car, which is OK, but not brilliant.
As you have the Z3 MC I would certainly give a Cayman a go.
