Hi Everyone,
Was driving my car the other day and noticed a drop in power, but was still driveable.
I did an OBD scan ,using a Carista scanner, and got the following error:
2A39 - P1024 - VVT-Self-Learning Function Faulty Lower Learning Range (Bank 1)
and a FF00 error which I haven't been able to find any link to.
After some digging on forums, I found some suggestions of the eccentric shaft sensor potentially being the issue. The connector was clean and when running it disconnected I got new errors coming up - so I'm confident its not the sensor.
Then driving it to work this morning the car went into a limp mode, basically wouldn't rev above 3k. I scanned it again and still only the P1024 error. I've ordered a k+dcan cable to be able to run Inpa/ista, so hopefully I can get some more detailed diagnostics and run the relearn function that others seemed to have had success from. I do also currently have the dreaded handbrake, TPMS and DSC amber lights up on the dash, but i'd be surprised if the two were linked
Went to try and start the car after it sitting for a couple of hours and it won't start. It cranks but won't fire.
Just wondering if anyone else has ran into the same error ,or similar, and has any tips, hints or solutions.
Thanks in advance
Thanks in advance
