Robsterrob
Hello!!!
I placed an order for a Z4 20i MSport over the weekend - prettly big options list, so I now need to wait until it's built with expected delivery in December.
Sanfran red with ivory leather, tech pack, comfort plus, M Sport Pro and also stuck with black gloss trim rather than the odd diamond aluminium stuff.
Quick question - Parking assist (as part of the tech pack)- according to the online configurator, this means that the car will parallel park itself, and reverse assist will steer the car for you when reversing short distances (I've cut and paste the relevant bit from the website below:
Parking Assistant includes the Rear view camera, Lateral parking aid, Active Park Distance Control as well as the Parking and Reversing Assistant. The Rear View camera provides a clearer view behind the vehicle. The Lateral parking aid uses additional sensors to monitor the areas to the sides of the vehicle and to represent obstacles on the Control Display. Park Distance Control, provides support in reverse parking situations to avoid collisions. Parking Assistant uses linear guidance to park the vehicle automatically into and out of parallel parking spaces. The system measures potential spaces while driving past them at a low speed and at a maximum distance of 1.5m from the row of parked vehicles. Once a sufficiently sized parking space has been found, you only have to turn on the indicator and the Parking Assistant takes over the steering, selects the correct gear and accelerates. You only have to monitor the parking procedure. Parking Assistant emits an audible signal when the parking process is over, and shifts gear into 'P'. Pulling out of parallel parking spaces works in the same way. Reversing Assistant records a road you have driven forwards so that it can reverse the vehicle in the same direction if you wish.
Is this the case on 2020 newly built cars?
Can't wait until December - shame it will probably be awful weather by then!!
