Z4 boot brake light
Chumley Z4
New member
Hi
Just picked up our new 2004 Z4 3.0. The boot brake light has a small bit missing off one of the corners. I have been searching the breakers but not found one yet. Anyone out there know where I can get one from?
Best bet is from a dealer. They are prone to cracking. I bought a new one a few months ago. It cracked after a month so was replaced for nowt.
Clear are also cheaper than red.
Chumley Z4 said:
Hi
Check this post: http://www.zpost.com/forums/showthread.php?t=623996
Order from Sopers BMW in Lincoln and mention you are a member here - you'll get a 10% discount.
Clear ones are cheaper than red ones. Make sure you get three 40N springs too - your current ones are probably the older, stiff ones, which partly cause the cracking.
Removal and install guides can be searched for - don't tighten the nuts much on installation.
