Progress update
Front speakers installed, woo!
Whats happened since the last update, my brother did a superb job of upgrading the tweeters. You can see the before and after below. Not much difference to see on the front, quite a difference on the rear though. A big thank you to him for doing this
From left to right, original BMW / stripped Dyn / original Dyn
Side on comparison of the stripped Dyn and original BMW.
Mid range required stripping to fit in the stock location. The mount hole spacing was not quite right, made a couple of cuts with a Dremel. That allows the speaker to fit on to the original mount threads. A small spacer is needed to stop to the cone from touching the speaker grill on the door card. End effect a completely stock looking door.
Mid range mount ring
To get the wires into the doors I’m using the stock door connector and adding extra pins & wires.
New pins
Had to remove a few strands of copper to get the cables to fit into the connectors. Its only a few strands and for a really short distance so shouldn’t make any difference.
The passenger side had the BMW wiring for the midrange in place. This was removed to make way for the thicker gauge wire I’m using.
Bass speaker with mount ring and foam sealant to isolate the front and rear of the speaker.
Added some sound deadening behind the bass speaker.
Only had a short listen to it, really happy. It needs a little EQing, but I don’t think it too far off. My brother suggested setting up a cross over point. At the moment the fronts are playing full range ( it was easier to get it going quickly ) It has nice clear vocals, instruments sound really good. I am amazed how much bass the Dyns are producing in this setup. The subs add low end volume to complete the sound. Once setup properly should work well.
As a little extra I’ve added puddle lighting to the doors. This required an extra wire though the door for power ( hooked into the interior lights ). I have also prepared the wiring to added the Z4 extended lighting into the door handles. This will be an orange glow on the inside under the handle.
White wire added to pin location 1.
Up next will be to changing the signal processor to an Audison bit Ten D. This will add EQ functionality
