lol I live in South Africa, I definitely don't have it set to miles, I would have a serious amount of speeding fines if that was the case.
With regards to injectors, I checked last night and they are definitely Revision 12 injectors...all of them. and as far as I recall I think they were replaced less than 10k km ago.
I have no miss fires
I had a bad 02 (Lambda sensor) a while back but I replaced that last year September with a brand new one and both are reading correct AFR values that being 14.7 while car is idling and making there way to +-12.5 under boost. I ran some logs yesterday to be sure of that.
Also on that note, before changing that bad o2 sensor, I used to get o2 sensor errors all the time on MHD and Carly which I no longer get since changing it out.
I can't see it as being bad coils or spark plugs at this time due to the car not having a missfire or rough idle.
What I do know is that when I did the oil filter housing gasket and I had to pull the intake manifold back I had a good look at my intake ports and the carbon build up was VERY VERY bad. However when the carbon build up is bad to the point of causing bad fuel consumption wouldn't it also cause a rough idle?
My brake calipers are perfect....I changed all 4 pads recently and replaced sensors and lubed those calipers up very well, they are functioning perfectly.
