Z4 3.0si Subframe advice - Help
orca48
 Stevenage, Herts
Hi Guys
Help needed
Part 33306776593 was found on the following vehicles:
Z4 E85   (10/2004 — 08/2008)
Z4 E86   (10/2005 — 08/2008)
Does anyone know if other Z4 subframes can be used on the Z4 3.0 si, Real OEM states that the above is solely for the Si version.
Look forward to hearing from anyone with help/advice
Hi Guys
Help is required, can other Z4 rear subframes be used on the 3.0si, Look forward for advice please
I don't know if this will help but at the bottom, it implies that 2004 onwards will fit.
  • Screenshot 2023-03-27 at 12-07-32 Original BMW rear axle carrier (33306776593).png
I am pretty sure on the 3.0si it is a bespoke subframe so I would be surprised if any others fitted and worked .
I was surprised that they'd have different carriers so I thought I'd have a play with RealOEM and it does very specifically differentiate between the 3.0si and everything else, even the straight N52 3.0i.
Presumably the diff is larger on the 3.0si.
I have an Si subframe next to a normal subframe in my unit at the moment, some very subtle changes might be worth me taking some measurements.
So I pulled up both subframes next to each other. Grey subframe is from an Si and the rusty one from a 2.5i. I’ve measured between the bush hole centres and they’re the same. Also bush size is the same. Roll bar mountings are the same, my last thing to check is the weight like with Z3’s the subframes internally had strengthening braces so if I weight these two subframes and see how much they differ, I’ll need to remove the big bushes to make it closer.
Interested to see where this goes, found this alot on Z3’s parts are actually the same between models but have different part numbers, I had a friend in BMW unofficially confirm this.
Hi Joycey
Thanks for the info, how did you treat the grey subframe
I brought one from the US today for $100, but extra $250 for shipping, off a car with under 45,000 on the clock
orca48 said:
Hi Joycey
I had it grit blasted to clean it up, then Zinc coated so it can never rust again then powder coated grey on top :) I have an account with our local powder coaters. Cost was £60.
It will as I always thought that they were different . If they are the same that makes finding a "spare" much easier :thumbsup:
