Only a couple of things left to do on this project so listing for interest.
BMW Z4 E85 3.0i manual
Very good history and lots of work done
5 previous owners
140k miles
MOT Nov 2022
Sterling Grey with good 107's
Heated and memory electric M-Sport seats
Lit 6 speed knob fitted
2 keys
Folding mirrors, rear dimming mirror, auto lights
List of things I've done
Engine:
Vanos seals replaced and rattle rings, valve cover gasket etc
Water pump, thermostat and antifreeze- recent expansion tank fitted
New Spark plugs
Oil and filter change
Air filter and cabin filter changed
New aux and AC belts
New gearbox oil
New diff oil
DISA checked
Suspension:
Bilsten B4 front shocks, Lemforder top mounts and drop links.
New ARB bushes front and rear
Monroe rear shocks and Bilsten top mounts, new drop links
New rear springs
Brakes:
325mm front discs, calipers and carriers fitted.
Braided hoses fitted and new pads
Calipers painted silver
New rear discs and pads, braided one piece hoses fitted
New hard brake lines from middle of car to both rear sides due to corrosion
Brake fluid renewed and bled, clutch bled.
Other:
CDV deleted
GM5 relays renewed
New boot hinge fitted
Polished headlights
LED lights fitted to internal and number plate lights
New black/silver grilles and new lower grille
New fuel cap seal
Fitted aux and aux panel
Roof motor replaced and put into the boot
Fitted new bonnet alarm switch
New bonnet badge fitted and front struts repainted
Roof cleaned and waterproofed
New high level brake light fitted
All arch liners off and cleaned
Both door membranes checked and repaired/resealed, Bowden cable (drivers) fixed
Sound generator foam removed but in glovebox
Wiper scuttle cleaned
New slam panel strip fitted
Wind deflector fitted
Steering wheel recovered and fitted black trim
15mm rear spacers
I cleared and fixed a couple of airbag codes and have repaired/replaced the steering angle sensor, previously I know it had the RTAB bushes done.
Only fault I still haven't sorted is the drivers door mirror does not fold on the switch- I assume its been knocked off and replaced with a non-motorized one- still looking! There is no wing rust but there are a couple of minor scratches on the front near side wing- nothing major.
I'm near Lincoln, test drives welcome! I may sell the car at a lower price without the M-Sport seats as I realize they aren't for everyone!
As it stands £5,750
Stuart
5 previous owners
140k miles
MOT Nov 2022
2 keys
Engine:
New Spark plugs
New gearbox oil
New diff oil
DISA checked
Suspension:
New rear springs
Brakes:
Other:
CDV deleted
GM5 relays renewed
Polished headlights
New fuel cap seal
15mm rear spacers
As it stands £5,750
Stuart
