Z4 2004 water leak in boot
Steve19
New member
Hi everyone I’m a new member as of today
I have a problem with water leaking into my boot on my z4 2004 , can anybody help
Welcome aboard.
Firstly, where is it getting wet?
If it's one side or the other then it's most likely to be the screws that mount the rear light trims letting water past them.
If it's in the middle and round the battery tray then the main culprit is the third brake light: either cracked or the seal has failed.
Also consider whether it may be building up in the wells in front of the rear wheels and spilling over.
Then you are looking at moving the roof motor into the boot before it dies (which tbh, you should be thinking of anyway)
enuff_zed said:
Welcome aboard.
Pretty much covered all options for the op. OP- welcome along :thumbsup:
Welcome to the forum Steve, and good luck finding the source of your leak. :thumbsup:
BTW it's an unwritten rule on here that we like to see photos of new members' cars!
Interested and useful information.......off to the garage to make an inspection .....hopefully I won't find anything.. :cry:
