Z4 2.5 Roadster - Engine management light
Altsel
This light has reappeared after a major service, is there a DIY way of removing the warning caption from the instrument display??
Altsel said:
No - can i do anything to reset the pesky light?? ideally without taking it into a garage again.
If the light has just appeared after a service have you tried taking it back to the garage to hear their response?
The car runs a treat! - can I remove the caption by twiddling buttons and stalks inside the car as some youtube viduos suggest ?
go back to the place that did and tell them to reset the lights, if they cant or wont there is a carly thread on here find out who is the nearest member and ask him if he will take a look and reset it. and no you cant reset it by twiddling your knobs :)
out of curiosity, is JUST the EML thats on ? nothing else ?
No - it has to be reset via the OBD port as above. Can you upload a pic or describe which light you mean exactly? The fact that it has a light on means it will have stored a fault code which should help to identify the problem. The above is good advice - your first port of call should be to take it back to the garage who did the service if it came on as a result of that.
