Z4 2.2i 2005 Roadster, Titan Silver, Sport Seats
TomR
Owned since 2019 and only selling now as we have a baby on the way. This a well spec’d car with a few sought after extras. It has been on some great road trips to France, Devon, Cornwall, Wales and Yorkshire, so hasn’t been sat around gathering dust since we’ve had it.
It has been mainly kept in a garage when at home and run regularly through the winter months.
£3650
Located in Cheltenham, Gloucestershire.
Main details are as follows:
• 82942 miles
• MOT until November 2022
• Full service history
• HPI Clear
• 05 Plate
• 4 previous owners
• 17” alloys with 5-5.5mm Michelin PS4 tyres all round
• Heated sport seats
• Multi Function Steering Wheel
• Cruise control
• Sound generator added
• Stubby antenna, but whippy is included as well
• Auto dimming rear view mirror
• Upgraded speakers (added door speakers and footwell upgraded)
• AUX input
• Bluemusic Bluetooth adapter
• Machine monkey exhaust tips
• Clutch delay valve remove
• ZHP
• Clear side indicators
• Roof motor replaced and re-located to the boot
• Two Keys
Negatives:
o There are a few scuffs, stone chips and small touch ups. Nothing major for a car of this age, but it is not perfect.
o Handbrake sets quite high as a couple of teeth are worn lower down. It’s been like this since I bought it, never had an issue during MOT. A replacement mechanism included in case it is needed in the future. Could also be set very low if preferred as the first few teeth are fine.
o Last few MOTs have had some things to fix, but all work done at the time to sort any issues (detailed below)
Service work done:
o Crank case breather and pipes replaced (MOT 2019)
o Front shocks replaced (MOT 2019)
o Front lollipops replaced (MOT 2019)
o Main and door airbag ECUs replaced and coded (MOT 2019)
o Rear brake lines replaced, front to back (MOT 2019)
o MAF Sensor replaced (Bosch unit, 2020)
o Sparkplugs replaced with NGK Platinum plugs (Pro-active maintenance 2020)
o Rocker cover gasket and bolt seals replaced, torqued up in correct pattern (Pro-active maintenance 2020)
o Exhaust gaskets replaced and new bolts fitted (Fixed a blow from the exhaust 2021)
o Front brake flexi pipes replaced (Needed one joint tightening slightly at MOT 2021 to pass as it had a very minor leak, hence failed test, brake fluid changed at the same time)
o Rear shocks replaced (MOT 2021)
o Recent intermediate oil and filter change using MANN oil filter and Castrol Edge 5W-30 oil (2022)
• Service History (details taken from booklet):
o 12537 – Oil Service
o 25166 – Inspection 1
o 40807 – Oil Service
o 52643 – Oil, Air filter, Fuel filter
o 61896 – Oil, Inspection 1, Air filter
o 73010 – Oil, Inspection 2, Air filter
o 77461 – Oil, Inspection 1
o Next service due 5950 miles
Overall a very solid little car that has been well looked after and given us some great times.
Please let me know if you want any further information or would like to arrange a viewing.
Test drives welcome with proof of fully comp insurance.
Some Pictures
Some more
Nice car, sensibly priced. Seems a bit of a bargain given the mileage and the kit on board. GLWTS
Smart looking car that must be a good buy for someone, especially with those M-Sport seats - GLWTS. :thumbsup:
TomR said:
Hi Paul, I’ve replied to your PM.
I visited Tom today and had a short test drive. Tom was gracious with his time and his thorough explanations about his car.
Firstly this is an absolutely cracking car that will be snapped up by a very lucky person. It is a great testament to Toms care and obvious attention to detail. It’s looks, condition and drive belie it’s age.
Secondly I am too big boned (said my mother) for this version of the Z4. I will now have to look for a newer, wider, one!
My loss, somebody’s gain!
Paul
