Very sorry. Couldn't resist. And to be fair, your previous write up was one of the best inputs to the forum for quite a while.johnsi02 said:You are a cruel and heartless man with ice cold blood running through your veins!
Z4paul said:That's great Ian, they certainly are fantastic cars but problems like this can sour things a tad. Surprisingly I have just read a post that suggests the later 2.0 e89's suffer something similar, not hudtce85s then. Jave you even dared approach bmw for a solution? Might be expensive but give you peace of mind.
Paul
Hi Ianjohnsi02 said:Result. The manifold is back in one piece. A weld on the join with a CAT was broken. Fixed by a man with a mask and a very hot implement.
But.
There’s a real issue with parts if you’re not so lucky. Basically it’s a second hand one from a breaker (Quarry Motors were great and had one on standby for me) or a genuine part at nearly £1k. Ouch.
Lucky escape this time.
Thanks Ian, good to know you had some luck finding and buying a replacement (if it had been needed of course) . Best of luck with the car, summer is on it's wayjohnsi02 said:Hi Paul.
£275. And the guys there were super helpful too.
I did find another one that was £335.
It’s a bit of a worry that the aftermarket new options are so nonexistent though.
Bit of a z4 virgin tbh and this thread was very much about the manifold issue...but if your having problems / have a code that you can ask for feedback on and suggestions on what to do next then I would start a new thread on part of the forum that would be most helpful to you. I guess the codes /fault you have might steer to you to a particular part of the forum...rajen44 said:Hi guys I'm having the same issue in terms of the code cropping up. Engine runs fine, apparently theres no crack on the manifold and I've had the head gasket replaced too. Any idea what it could be? Mines a 2008 2.0. Thanks.
