Your specialist subject: The life and times of BMW N54 turbo chargers and upgrades
B21
Elite
 Scottish Borders
The BMW N54 was fitted with two Mitsubishi low pressure (8 PSI boost) TD03 turbochargers.
Cylinders 1-3 and 4-6 each blew exhaust gases through a relatively small turbo..the air from a common airbox was ducted to each turbo individually, then the compressed air was merged into a single duct before going through a single forward mounted intercooler before entering the inlet ports via a single charge pipe.
TD03 refers to the 'frame' size..ie how large the overall castings were that house the turbine and compressor parts..TD03 being small..a BMW N20 engine has a sigle TD04 turbine.
The logic of two turbo chargers was to reduce throttle lag and allow quick spool (up) of the turbos through small turbines and compressors having low mass.
Not much puff was asked for (8 PSI boost) to take and engine that would have made about 250 bhp without boost to 335 (35is) with boost.
In my case at 60k miles I took my turbos of to replace them with two new TTE500 'hybrid' turbos.
They are called hybrid because they are a frankenstein turbo..that is the overall unit is made from an orginal new Mitsubishi BMW N54 turbo, but the turbine wheel, compressor wheel and other parts are designed and supplied by others..
Sadly after 2 years and 20k miles the rear TTE turbo developed an oil leak..there was a leak form the external oil feed caused by the Indy in Darlington not fitting it correctly..(cocked over and nipped the o ring)..but after fixing that more oil came out of the turbo itself..you can see the burnt oil on the clamp that connects the hot section to the cold section.
On examination it has a lot of lateral play and some longtitude play in the bearing..so much so that the turbine plates are hitting the main structure!
After looking at various options I was only really left with one..send it back to TTE in Germany..essentially not repairable by any UK turbo overhaul house due to specific TTE parts.
The distributor said they had sold over 8,000 and only had 20 duff ones..must be unlucky..Indy confirmed all oil feed lines were OK..heh ho..
Now having the orginal 60k mile originals I've decided to get them upgraded as there's a £1,200 saving if you have the luxury/time to send good units back..mine look in really good condition apart from some play in the waste gate hinge..which is a well known weak spot on the stock turbos.
So 2 boxes via Fedex to Germany..1 TTE500 to be refurbed and 2 old OE ones to be converted to TTE spec..at least I shouldn't be off the road for a prolongued period with those as back up..1st world problems..
The pics show the two sets of turbos..you can see that a TTE turbo takes the stock Mitsubishi part new and starts from there.
You can see the bigger turbine wheel and whilst not intially obvious, the compressor wheel is bigger and also has a 50mm outlet vs 47 mm ish OE oulet..turbine speed is up from around 120k to closer to 200k..hence more boost (I'm hitting 21.5 psi peak) but more wear..
We will see what gives..
Is it that much of a performance part that it needs uprated oil pumps or sump baffles etc fitted? Sounds like the upgraded turbos should probably have been more reliable than the originals if they are quoting such low return rates. Do you think you were unlucky or have you got an underlying issue still to solve?
Yup went through that process..the Indy says all the feed lines were clear and not twisted which I suspected..
Making plenty of boost and no MHD logging issues..
Stock water and oil feeds ..unusual for an uprated requirement...normally oil feed is restricted due to excess available...distributor who sells these for Mercs, Porksters and Audis as well reports that in this 'baby' size very few issues...did discuss sending its sister off as well..view was unproven as to whether that would be a good idea..no signs of distress from it..his view..any uprated turbo based on an original structure is likely to be less reliable than the OE version..interesting...he did mention that the much bigger turbos do fail more often..but this is the baby at 500 they do 600s and 680s too!
Have you ever been tempted down the bigger single turbo route? Simpler plumbing, fewer moving parts? Not sure if folk do this on Z4s, but it's the normal route on Supras, RX7s, etc. - other performance TTs.
The primary arguments against single turbos is slow spool ….generally regarded good for sprints but not so good for roadwork…great top end power …so in N54 world twin turbo is still the preferred solution for road work…
Sometimes they just fail especially when a hybrid is asked to do more than the stock unit
Hopefully isolated incident
So my old original Mitsubishi turbos from my E89 have now come back, upgraded to TTE500 spec and badged as such…
There are two routes to these types of upgrades..take either a brand new Mitsubishi turbo and then gut the internals / bore it out / fit new turbine and impellers, maybe upgrade the waste gate bushes and flaps..the other is a brand new Chinese turbo with new bits..not sure which is the best route..given installation, tuning etc I’m pretty much wedded to the hybrid route ..
My blown turbo and its sister are due back late September..no response to my multiple queries on what caused the failure…not good.
The turbos are handed so 4 turbos make two pairs…I’ve got a hot swap pair going forward…
That will avoid a 8-9 week downtime..hopefully..
Out of interest the upgraded set now are TTE serial numbers 425/426..the old set are 227/228..that means they’ve only sold 210 pairs of these..and they’ve sold a 100 pairs in the last 3 years..
That’s not much compared to some of the American based hybrids..
£2,250 later ..not including the price of the turbos..back on the road..that’s the price for a decent Indy to remove and refit turbos plus a DCT new sump and oil change..if you can’t afford to play…feeling smoooooth…n quick..
