You might want to check this on your ///M
srhutch said:
Here is the post I found about emptying the plunger before reusing. Torque setting 52 ft lbs by the looks.
http://www.e46fanatics.com/forum/showthread.php?t=1003185
nice find!! that seems about right.... but won't hurt to check other sources!
srhutch said:
pvr said:
That is 70.5 Nm for those that use proper torque units :poke:
Bloody foreigners :lol:
You better stick with Metros / Maestros and such wonderful cars if you want to use those funny measures and not a mainland European properly metriced car :P
Pretty sure mine has some residue on it but never thought much of it. Will clean it up and give it a tweak.
Just had an Oil Service today with the advisory of a slight oil leak in the engine, probably the timing chain tensioner. Same problem as above I assume, not able to fix this myself though
Have you got a socket set Mark. If do buy yourself a 32mm socket and nip it up.
Or ask where you had it serviced to nip it up for a drink.
It is. If your passing Burgess Hill one morning let me know I'm happy to meet you and nip it up for you even.
