Well tonight is the first time I have used the car in the dark since having the springs replaced and noticed the xenons seem very low set on the road.
Turned off the engine and re-started to see if this would sort it but it appears not. Even the headlight salute thing that they do when you first turn them on only lifts and drops slightly, nowhere near how they did before and the noise the motor makes seems different... More strained somehow??
My first thought is that one of the levelling sensors on the suspension has been damaged while replacing the springs. I was under the impression though that these are located on the rear shock absobers. The only ones that were removed were the front ones as obviously the rear springs are in isolation to the shock absorbers?
Anyone else had this problem and can shed any light?
Thanks.
John
Thanks.
John
