Xenon issue.
Neither xenon are working on the drivers side connector however both work on the passenger side harness.
Measured the volts with a multimeter.. And got this. Why is the drivers side connector measuring nearly no volts on the pins that should be measuring higher? Any ideas?
The headlights are controlled from the LCM module (pcb behind the headlight switch). I can't imagine why it would control each headlamp individually but I'm struggling to come up with any other reason short of a loom fault which I don't think I've ever encountered in my 5yrs on this forum.
Aye swapped the whole light across to the other side.
Its odd, could it be a faulty earth? I'm going to unplug the terminal connectors and check them one by one later.
Oddly it posts the bulb out warning when it's removed completely from the harness but nothing when it's connected even though it's not working.
Through process of elimination i've since found...
When lights are turned on Low Beam the
High Beam pin gets 12 volts off chassis and with connector earth (PIN3)
Low Beam pin gets 0.02 off chasis and its own connector earth (PIN7)
When lights are turned to high beam
Shutter on PIN 8 gets 12 volts off chassis and its shared earth with low beams on Pin 7.
So whatever the issue is, its directly linked to only the low beam pin. Doesnt appear to be the earth.
