Ok, done the forum searches and a few investigations, so now have some questions...
Problem I have is the driver side headlight auto-levels fine on every startup, but the nearside headlight is not cycling at all - it stays level so is fine for driving, but does not do the down-and-up cycle when the headlights come on.
I know about the sensors but my first question is, do the sensors affect both lights equally, i.e. there is no circuit difference in the feeds to both headlights? So I don't need to look at the sensor feeds if one headlight works fine?
Also, is there any other test I can run before settling on a failed stepper motor as the cause?
Finally does anyone know the connections for the small plug (rather than dismantling the headlight to find its a cold join, or similar) as I could just try a voltage feed across the plug - if I know the connector settings....
Cheers all...
Cheers all...
