XCar-Style roof module operation
tintoverano
closing the windows doesn't work by 2 click on the remote's close button, everything else seems to work so far
I turned off comfort related settings as suggested in the manual, but still
ideas?
thanks
RobbiZ4 said:
2nd: I always learn the guys to count between the key presses - twentyone, twentytwo, twentythree, twentyfour. Press the button only with a delay of a second.
thanks, I'll give it some more try
tintoverano said:
mcbutler said:
You press and hold the close button to close the windows..
I guess this one is for Smart Top, thanks though
The 'press and hold' is for the standard car, I have no idea about the smart top module I am afraid.
With anything electrical on this car it is always worth looking at your battery as a potential culprit if it is old or the car has been stood for some time.
Good luck :thumbsup:
tintoverano said:
but one needs the comfort module in order this to work, no?
I believe it is an option called 'comfort access', you can put your VIN in here https://www.mdecoder.com/ and it will tell you the original spec of the car and any options fitted at build.
yep, I don't have it - that's why I went for the XCar thing
