Hoping someone more technical than myself can shed some light on a problem I have.i am a mechanic but never got into electrics,anyhow here goes....
I purchased a z4 2.0 2017 (must be one of the last registered),it was a cat s salvage but damage was to bonnet,bumper,airbags,certainly not major damage,all bolt on stuff and no way a cat s unless they regard a bonnet as structural.
I have done all the bits,airbags,tensioners,bonnet hinges and locks,all new stuff.
I was waiting of the battery lead which arrived today and I assumed would fix the none start issue I have,but it hasn’t so I am asking for the help now!
There isn’t a ignition feed to the starter,won’t crank.if I remove the ignition wire off the starter and test it there’s no voltage.if I push the key in and press the start button nothing happens,if I at that stage flash a feed to the terminal it starts and runs fine.
I wouldn’t expect the ignition feed to be fused so I haven’t checked any,I was realy hoping the positive blow off cable was the culprit. Carly just says a starter vault
