So, after a number of iterations, I've got a semi-wired solution for my iphone X that works for music and satnav through the stereo which is stable and of acceptable quality, however I'm now aiming for something more integrated that will allow the following:
- OEM Head unit and steering wheel controls for track skipping
- Minimal visible wiring
- No plugging the phone in
- No battery drain when car locked
- Phone in portrait orientation in the corner of the windscreen
Target setup will be:
- Hidden Bluemusic 3+6 bluetooth adaptor to replace the CD Changer: https://www.amazon.co.uk/dp/B0773MX7BG
- Wireless windscreen mounted holder/charger wired in to a switched fuse
Does anyone have any recommendations for the latter, either for a mount and transformer/usb location and wiring behind the dash?
My current, slightly convoluted, setup is as follows:
- Business sat-nav with cd changer (yes, it's a odd spec)
- Aux-in next to 12v socket
- Artek screen mount: https://www.amazon.co.uk/dp/B01F3M5EAU
- Tunai Firefly Bluetooth adaptor: https://www.amazon.co.uk/dp/B01HXXJPWK
- Ground Loop isolator: https://www.amazon.co.uk/dp/B01LYYRT7M (to avoid aux drop-out)
- 2x usb socket
- lightning cable draped over the steering wheel
- 2x usb socket
