D daveparkinson Member Aug 26, 2014 #1 Drivers wiper has stoped working near side works fine help needed to fix
R ranski Elite Sutton Coldfield Aug 26, 2014 #2 not moving? you will need to remove the scuttle, then the wiper linkage to inspect
G Grumpyowl Veteran North East Derbyshire Aug 26, 2014 #3 Go into the E85 How to section. Misc. Wiper resting reset degrease thread.
T TheHoff Member Wickham, Hampshire Aug 26, 2014 #4 ranski said: not moving? you will need to remove the scuttle, then the wiper linkage to inspect Click to expand... Agreed.
R ronk Lifer Durham Aug 26, 2014 #5 Afraid that most things like this are not the norm and without the crystal ball will need the spanners out! I'm not being negative, just a bit pragmatic. It does appear to be either linkage or spline drive without the benefit of more detail.
D daveparkinson Member Aug 27, 2014 #6 Wiper fixed worn out linkage made a wire washer. Fixed it to the ball clip it around the complete joint works perfect
D daveparkinson Member Aug 27, 2014 #7 Wiper fixed worn out linkage made a wire washer. Fixed it to the ball clip it around the complete joint works perfect
